I am importing an FBX model to Infraworks. The model was done in Revit . The mesh material applied to the wall doesn't show the cutout . In Revit the rendering looks good
Solved by Nicola_Ianeselli. Go to Solution.
Hi @NDM_USER,
can you explain a little bit more?
Maybe it is only me but it is difficult to understand what's in the image..
Best
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
In the picture you see a wall exported from Revit to IW via FBX. A mesh material is applied to the wall . The material was applied in Revit . In Revit after the rendering the wall looks like a wire mesh ,it's a see-through.
Hi @NDM_USER,
oh ok, now I see.
No you cannot do anything related to alpha channel in Infraworks with textures. There is no transparency for material coming from the outside.
There is the need to wait.
Best
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
