Can anyone tell me how to get my infraworks model to come into lumion at 0,0,0? I've figured a way to bring in the model close to 0,0 but like 6000 ft in the air, we've been managing it for a while but I am wondering if there is a way to bring in in at 0,0,0.
Solved by John_DeLeeuw. Go to Solution.
Hi @pp0dYou can try send to 3Ds Max, move there to 0,0,0; export and import in the Lumion!
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
@pp0d I understand, but Infraworks "works" about GIS
@pp0d, you can Export and Offset your InfraWorks 360 model to the Origin (0,0,0) right from the software. The screencast below shows you the steps and settings to take. It's realy easy actually.
The model is on large coordinates first and after FBX export and opened in Navisworks its right at the origin. Should work the same for Lumion also.
Let me know if this helps you?
