So, I was playing around a bit with the watersheds in the Drainage tools in InfraWorks 360 and I decided to do a quick comparison. How do the numbers that InfraWorks comes up with compare with what I get when I calculate them myself. According to the help, the regression analysis uses the USGS National Streamflow Statistics program so, I went and downloaded it. I ran it with the same numbers as I put into InfraWorks and it came up with the exact same answers!
It's always nice to confirm that the magic box is doing what it says it's doing!
Solved by scunningham. Go to Solution.
Thanks for sharing this! (I know, 3 years later is a long time to wait for at thank you!) 🙂
