Does anyone know a way to make the surface slope analysis display in percent instead of degrees?
Does anyone use degrees when describing land slope.
Solved by Nicola_Ianeselli. Go to Solution.
Nope, that's not what I am looking for. Apply a Slope Analysis to a Terrain Theme. Notice the slope is in degrees, not percent or rise/run.
My friend @tcorey,
I don't think it is possible to do what you are looking for. Not in this version.
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button
Nicola Ianeselli
BIM Manager
Twitter | LinkedIn
Infraworks Ambassador
Want to present in Infraworks? Vote this up!
I received a tech support reply from Autodesk stating that this is not possible. This is a pretty basic concept. Go to any engineering company in the USA, I don't know about the rest of the world, and they calculate/display slope as either percent or ratio (run:rise or rise:run) I have never seen an engineering firm wanting to display slope in degrees. I'm not saying it has never happened, but I've never seen it.
Is this in the documentation anywhere that slope analysis is in degrees? Searched a bit and didn't find anything.
We are running version 18.0.45.0.
