InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Custom Traffic Sign
5 REPLIES 5
javier.barcelo
1585 Views, 5 Replies
Custom Traffic Sign
Hi there,
I'm struggling big time to create a custom traffic sign and then import it into Infraworks. This is my workflow:
  1. Blank drawing in Civil 3D. Dwt is in meters. Create shape of sign (0.60m x 0.45m rectangle with fillet on each corner R=0.05m, thickness is 0.0016m). So I start with a rectangle, fillet corners, extrude it.
  2. I them move the solid to 0,0,0 and rotate it 3D using the rotate gizmo to have upside down.
  3. Apply steel generic steel material to the entire solid by drag and drop
  4. Create new material from image downloaded from the internet (see below). Format is GIF. I make sure the the size is matching the rectangle (0.60x0.45) and select None for both the horizontal and vertical repetition.
  1. I then apply this material to one face only by holding control when dragging. I then apply Material Mapping Planar to make sure it's nicely centred.
  2. Everything looks fine. So I export to FBX format. Select entities, no lights, no cameras, embeded textures.
I know jump into Infraworks, open the model and select the data sources/ 3D Model. I configure the object and first of all, for some reason I have to scale it up 100 times, otherwise it's tiny (Why!?). Infraworks is set in metric system in meters. I set type to City Furniture and select Interactive Placing, and all I get it's this.
I tried several things like not embedding the materials. I created a brand new sign even using another shape and picture. Same result.
Does anybody come up with this issue? Any help would be highly appreciated.
Cheers
Javier
Tags (1)
5 REPLIES 5
Matt__W
in reply to: javier.barcelo
Hi, @javier.barcelo have you seen this YouTube video by Jeff Bartels demonstrating how to create custom models for use in InfraWorks?
Matt Wunch
Revit Subject Matter Expert/sUAS Pilot
Twitter | LinkedIn
AU2017 - Code Blue Dr Revit - How to Resuscitate Corrupt Revit Models
Was this answer helpful? If so, please click the ACCEPT AS SOLUTION or the KUDO button.
Hi Javier,
Another simple option is to copy an existing stock .SFF signage model and modify the imagery on it. We had an awesome intern who wrote an article about how to do this a few years back. His article should still present a valid workflow: https://forums.autodesk.com/t5/infraworks-360-infratips/how-to-edit-stock-sff-3d-models-pois-trees-s...
Thanks, let us know how it goes.
Elliott
Principal Specialist, Infrastructure
javier.barcelo
in reply to: Matt__W
Thanks for your reply Matt. I have seen that great video and I actually followed his workflow step by step. The only difference I notice is that his images were created in photoshop while mine were downloaded from the Internet. I don't know if that is the issue but I do hope is not as I don't have the time to mack around photoshop to create my own images.
Regards
Javier
I just realised I missed one image related to the keep left road sign. The image below shows what I get in Infraworks.
I have a feeling that the issue may be with the units. Since you're having to scale up the FBX by 100, that may be throwing off the material planar mapping.
What happens if you scale the sign in AutoCAD before exporting it to FBX?
Michael Hurtado
Designated Support Specialist
Rail Community
