InfraWorks Forum
Welcome to Autodesk’s InfraWorks Forums. Share your knowledge, ask questions, and explore popular InfraWorks topics.
Cul-de-sac
14 REPLIES 14
Message 1 of 15
oriole.phillips
4307 Views, 14 Replies
Cul-de-sac
Any know of an EASY quick way to add a cul-de-sac at the end of a road? This would be a great idea to add to the next Infraworks update. Including a radius option.
Tags (1)
14 REPLIES 14
Message 2 of 15
I'm pretty sure this is a pretty heavily requested feature, but there isn't an easy way quite yet that I am aware of. There's this blog post that shows one way: HERE and I've used that before with success.
Most of the time though, if I'm doing a "quick and easy" cul-de-sac, I just do a 4 point "diamond" on the end of the road. You can change styles as shown on the blog link to remove the inner circle. Sometimes I'll just put a tree in the middle to make it look intentional! Maybe in the next couple releases they'll have this feature sorted out. I would imagine a modification of the roundabout coding could make it possible.
Message 3 of 15
A coverage area is the only way.  I have been pushing for this for 2 years now.
Edited....replied at the same time @JasonArtley did.
Todd Rogers
Message 4 of 15
There is a pending idea on IdeaStation, but I do as follows.
I create an alignment through the gutter and I apply a section, only gutter curb and sidewalk.
In the interior of the cul-de-sac, I apply a coverage area
If you have some difficulty to creating a more precise alignment, make in Civil 3D and export to your Infraworks model.
Eduardo Soethe Cursino
Civil Eng. | BIM Specialist
Soethe Cursino Consultoria | BIM for Infrastructure | LinkedIn
Autodesk Certified BIM Specialist: Road and Highways Solution
AutoCAD Civil 3D Certified Professional
__________________________________________________________________________
Se a resposta resolveu o seu problema, clique em Aceitar como Solução isso ajuda os outros usuários a encontrar rapidamente uma reposta e Kudos de gostou.
Autodesk Community
Message 5 of 15
Great idea, thx
Message 6 of 15
Great idea for proposd roads.
Message 7 of 15
@Eduardo.Soethe a Screencast showing this workflow would be a big help!
Eric Chappell
Message 8 of 15
Yes! I second what @Eric_Chappell mentioned. Maybe post it on the Knowledge Network?
Todd Rogers
Message 9 of 15
@ToddRogers-WPM @Eric_Chappell
I will make the video.... I had forgotten
Autodesk Community
Message 10 of 15
@Eduardo.Soethe PLEASE CAN SHARE THE LINK
Yoffre_Vargas/Educator_Expert/ECUADOR
Si mi respuesta solucionó tu problema, por favor, márcala como Solución Aceptada y haz clic en Me gusta.
Message 11 of 15
obicad
in reply to: ToddRogers-WPM
Todd my brutha! Did you ever get a link to a video of how to do this particular culdesac?
Message 12 of 15
ToddRogers-WPM
in reply to: obicad
Hey dude! No, it was never posted. @Eduardo.Soethe, did you ever do this?
Todd Rogers
Message 13 of 15
https://knowledge.autodesk.com/es/community/screencast/ed0a6713-9c59-4cda-8824-4831a1c426f7
YOFFRE VARGAS - ECUADOR
correguido
Usa aceptar como solución o kudos si la respuesta dada resolvió tu problema
Message 14 of 15
Hi guys sorry for the delay in answer.
I did a sequence of images and hope it helps.
Captura de Tela (1).pngCaptura de Tela (10).pngCaptura de Tela (3).pngCaptura de Tela (4).pngCaptura de Tela (6).pngCaptura de Tela (7).pngCaptura de Tela (11).pngCaptura de Tela (12).pngCaptura de Tela (13).pngCaptura de Tela (14).pngCaptura de Tela (15).png
Autodesk Community
Message 15 of 15
This post has been featured on the Autodesk Civil Engineering Community Center http://civil-community.autodesk.com/2018/03/infraworks-forum-post-week-cul-de-sac/
Eric Chappell
Rail Community
