Informed Design Sample Content
Explore sample datasets and reference materials here to assist with onboarding and continuous learning of Informed Design capabilities
Wind Turbine sample Inventor Assembly
Contributed by:
The Zipped file can be downloaded from the link at the end of this article.
Included in the zipped file is an Inventor 2024 Dataset that features:
  • A simplified model state.
  • BIM definition data, including hosting.
  • A Revit MEP connector.
  • A product definition, ready for you to publish to Informed Design.
This dataset can be used to explore Static content, RFA Export, Revit MEP connectors, and BIM definition orientation tools. Use this dataset to understand the Revit 'always vertical' option.
Click here to learn about 'always vertical' in Revit.
Click here to learn how to publish static content with Informed Design.
Click here to learn about adding Revit MEP connectors with Informed Design.
Click here to learn how to orient your manufacturing model for Revit insert using the Family definit...
