Options too create multi-page pdf
for devolper is too send this pdf too "exportfolder"
exampel code thats i use in APS/Inventor i create all export item too exportfolder
before i send zip ACC-folder
Class ThisRule Sub Main() Trace.TraceInformation("Before PDF") Dim FileName As String = iProperties.Value("Project", "Part Number") PublishPDF(FileName & ".pdf", 1, 1) PublishPDF("Balcony" & ".pdf", 1,1) Trace.TraceInformation("Before After PDF") End Sub Sub PublishPDF(name As String, SheetStart As Integer, sheetEnd As Integer) Dim PDFAddIn As TranslatorAddIn= ThisServer.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") 'Set a reference to the active document (the document to be published). Dim oDocument As Document = ThisDoc.Document Dim oContext As TranslationContext = ThisServer.TransientObjects.CreateTranslationContext oContext.Type = kFileBrowseIOMechanism ' Create a NameValueMap object Dim oOptions As NameValueMap = ThisServer.TransientObjects.CreateNameValueMap ' Create a DataMedium object Dim oDataMedium As DataMedium= ThisServer.TransientObjects.CreateDataMedium ' Check whether the translator has 'SaveCopyAs' options If PDFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then ' Options for drawings... oOptions.Value("All_Color_AS_Black") = 0 oOptions.Value("Remove_Line_Weights") = 1 'oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = kPrintSheetRange oOptions.Value("Custom_Begin_Sheet") = SheetStart oOptions.Value("Custom_End_Sheet") = sheetEnd End If 'Set the destination file name ' oDataMedium.FileName = System.IO.Path.GetDirectoryName(ThisDoc.Path) & "\ExportFiles\" & name If name = "Balcony" & ".pdf" Then oDataMedium.FileName = System.IO.Path.GetDirectoryName(ThisDoc.Path) & "\" & name Else oDataMedium.FileName = System.IO.Path.GetDirectoryName(ThisDoc.Path) & "\ExportFolder\" & name End If 'Publish document. PDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) End Sub End Class
