Informed Design Generate Outputs: Exportfolder
Options Get the name off  the Exportfolder in Informed design
too export preview picture from APS/Informed Design
		      	ExportFilesDir = System.IO.Path.GetDirectoryName(ThisDoc.Path) & "\ExportFiles"
               	''' Radera ExportDir om den existerar
                       If System.IO.Directory.Exists(ExportFilesDir) = False
'                              System.IO.Directory.Delete(ExportFilesDir, True)
				''' Skapa ExportDir
                       System.IO.Directory.CreateDirectory(ExportFilesDir)
                       End If
               For Each deleteFile In System.IO.Directory.GetFiles(ExportFilesDir ,"*.jpg")
                   System.IO.File.Delete(deleteFile)
               Next
				''' Create JPG
				 Dim fileName As String = System.IO.Path.GetDirectoryName(ThisDoc.Path) & "\ExportFiles\Liftboy.jpg"
				' Get the active document
			    Dim oDoc As Document = ThisDoc.Document
			    Dim oModelRef As Document =  ThisDoc.Document
				Dim options As DisplayOptions  = ThisServer.DisplayOptions
   				options.UseDocumentDisplaySettings = True
  				options.Show3DIndicator = False
				Dim camera As Camera= ThisServer.TransientObjects.CreateCamera
					camera.SceneObject = oModelRef.ComponentDefinition
'				If side_exit_on_upper_landing = "Yes - on left side" Or side_entry_on_lower_landing = "Yes - on right side"
'					camera.ViewOrientationType = ViewOrientationTypeEnum.kIsoTopRightViewOrientation
'				Else If	side_exit_on_upper_landing = "Yes - on right side" Or side_entry_on_lower_landing = "Yes - on left side"
'					camera.ViewOrientationType = ViewOrientationTypeEnum.kIsoTopLeftViewOrientation
'				Else
'				End If
				Dim tg As TransientGeometry
  					tg = ThisServer.TransientGeometry
				Dim eyeDistance As Double
				   eyeDistance = 30
				      ' Calculate the x and y coordinates of the eye.
				Dim x As Double
				Dim y As Double
					x = 750
					y = 1500
				     ' x = eyeDistance * Cos(1 / 1 * (2 * pi))
				     ' y = eyeDistance * Sin(1 / 1 * (2 * pi))
				' Set the eye using calculated x, y and a hard coded z value.
					 camera.Eye = tg.CreatePoint(-x, -y, 1000)
					 camera.Eye = tg.CreatePoint(-x, y, 1000)
				Else
				End If
			    ' Define the up vector as positive z.
			    camera.UpVector = tg.CreateUnitVector(0, 0, 1)
				camera.Perspective = True
				camera.Fit
				camera.Apply()
				camera.ApplyWithoutTransition
				Dim topClr As Color= ThisServer.TransientObjects.CreateColor(255, 255, 255)
				Dim bottomClr As Color= ThisServer.TransientObjects.CreateColor(255, 255, 255)
					camera.SaveAsBitmap(fileName, 5000, 5000, topClr, bottomClr)
				options.UseDocumentDisplaySettings = False
  				options.Show3DIndicator = True
