Deleting / Relocating Product Definitions
Hi All,
I would like to suggest an improvement to Informed Design regarding product definition management. At this time users cannot relocate, delete or manage product definitions once published in a project on the ACC. This creates issues when wanting to relocate or delete product definitions from a project. Ideally a user would be able to carry out these actions through the Informed Design Portal, where a user could see all published product definitions in a project, delete or move these product definitions as required.
This would allow users to correct mistakes, if a product definition was published in the wrong location and remove one if a model is completely obsolete.
Thanks a mill,
Matthew
2 Comments
iwakura.takumi
Thank you for posting, as I've been facing the same issue.
I also request improvements to the functional issues you've raised regarding Informed Design. I believe it would be more convenient to implement changes allowing users to delete or move product definitions published to ACC projects as needed.
daphne_tsang
Thank you Iwakura and Matthew for your comment. We currently have development underway and should be rolled out shortly that would address this issue. Stay tuned!
