Informed Design Forum
Welcome to Autodesk’s Informed Design Community. Please share your knowledge, ask questions, collaborate on ideas, explore forum topics and meet the development team!
Publishing to Project Folder
7 REPLIES 7
Message 1 of 8
kylegT2ZZF
434 Views, 7 Replies
When I first started creating products for Informed Design I didn't create any sub-folders.  With the new update I'm no longer allowed to publish to the Project Folder but when I try and publish to a sub-folder I created it tells me I can only publish revisions to the original folder.  Any way to fix this?
7 REPLIES 7
Message 2 of 8
david_reaume
in reply to: kylegT2ZZF
DaVeR
Message 3 of 8
kylegT2ZZF
Hi David,
So is there any way to move my products to a subfolder so I can publish new releases?  Otherwise this last update has created orphan products that I can't update or delete.
Message 4 of 8
david_reaume
Moving Published Products to a new folder is not yet supported.  You should be able to publish new Releases of the existing Product even though it is in the root.  Have you tried that and it's not working?
DaVeR
Message 5 of 8
kylegT2ZZF
The first picture in my post is the error I get when trying to publish a new release to the root folder.  I can see all of the products but the Publish button is grayed out and there is an error message saying I can't publish to the Project Folder.
Message 6 of 8
david_reaume
I will need to look into this issue and get back to you.
DaVeR
Message 7 of 8
david_reaume
As it turns out, your current inability to Publish a new Release against an existing Product that has been published to the Project root is a defect.  We will address this issue as soon as possible.  My apologies for the inconvenience this has caused for you.  Until we release a fix for this you will need to Publish a new Product to a folder (with a different name if also to the same Project).  Thank you very much for taking time to report this and thank you for your patience as we continually push this solution forward in terms of quality and new functionality.
DaVeR
Message 8 of 8
To fix this, move the original project to a sub-folder, then publish revisions to that folder. This should allow you to continue publishing updates without issues.
Sign-up for a Live Demo
