Informed Design: Publishing failed - Autodesk docs settings?
AlessioRuf
AlessioRuf
Hello, everyone,
I am testing Informed Design and I wanted to ask if there are any particular settings to set in Autodesk Docs as it gives me a publishing error.
Have any of you experienced the same error?
Alessio
gareth_spencer_adsk
Hi @AlessioRuf
I am sorry to hear you are having issues publishing.
Your permissions level in the target folder to publish a product using Informed Design for Inventor must Create – ‘View + Download + Publish Mark-ups + Upload’ or higher.
Please also check the this "Input templateFileName doesn't exist." when exporting RFA or IFC from BIM Content in Inventor 2023" support post. We have had similar reports and this was the fix.
Gareth Spencer
Customer Adoption Specialist (Autodesk Informed Design Team)
AlessioRuf
Hi @gareth_spencer_adsk ,
thank you very much for your reply, I have now managed to get the workflow working.
The problem was in the .ini file and the missing libraries, I also reinstalled the interoperability tools.
Thanks again
