Informed Design Forum
Welcome to Autodesk’s Informed Design Community. Please share your knowledge, ask questions, collaborate on ideas, explore forum topics and meet the development team!
Informed Design FAQ
0 REPLIES 0
Message 1 of 1
TimeraAutodesk
877 Views, 0 Replies
Informed Design FAQ
What is Informed Design?
Autodesk Informed Design is a platform-based solution that brings manufacturing information to the beginning of the design process to inform design decisions and improve project certainty, prevent errors, and accelerate our customers' workflows. It allows subcontractors to define and share their construction products with architects, including any allowable customization of their building products. This provides designers with the ability to customize a building product for their specific needs and know the results will be accurate and manufacturable for their building project.
Why has Autodesk developed Informed Design?
Autodesk is developing Informed Design to address several challenges in the construction industry. Currently, building design decisions are often not influenced by what can actually be constructed. Construction processes tend to be iterative, manual, and slow, posing high risks and uncertainties. Moreover, data and tools are often disconnected, preventing processes from working efficiently at scale.
There are several major factors motivating the shift towards industrialized construction. Firstly, there is a significant global demand for buildings that is currently unmet. Secondly, there are considerable challenges associated with attracting and retaining talent in the construction workforce. Lastly, the traditional construction methods are not scalable. Every project starts from scratch, creating a one-off process that often results in waste.
Without optimizing our processes, it becomes difficult to achieve the necessary improvements in the industry. Thus, by developing Informed Design, Autodesk aims to help support the streamline of construction processes, reduce waste, and meet the rising global demand for buildings.
What is the price plan for Informed Designed? How much does Autodesk Informed Design cost?
Informed Design for Inventor is a complimentary add-in for Inventor, available for download and installation at no cost. However, generating manufacturing documentation through the Informed Design web portal incurs a nominal fee of 1/3 token per document (3 documents per token).
What types of subscriptions will be available for Informed Design?
To use Autodesk Informed Design, users will need the following licenses:
  • For Autodesk Informed Design for Inventor, you will need a license for Autodesk Inventor 2024 and upcoming releases.
  • For Autodesk Informed Design for Revit, you will need a license for Autodesk Revit 2024 and upcoming releases.
  • For the Informed Design Web Application, you do not need licenses for other software. However, if you wish to publish from Autodesk Inventor 2024 or download to Autodesk Revit 2024, you will need licenses for those products.
  • Additionally, a license for Autodesk Docs is required to save published Inventor product data templates, save the Autodesk Revit model, and save any generated outputs from the Informed Design Web Application.
What languages is Informed Design available in?
Informed Design is only available in English at present.
Is Informed Design included in any of the Autodesk collections?
All customers who have active licenses for hero products Inventor or Revit. This includes both stand-alone licenses of Inventor or Revit and licenses via the Product Design & Manufacturing (PD&M) and AEC Architecture, Engineering, Construction (AEC) Collections.
What training content is available for Informed Design?
Customers can access the following sources to learn more:
  1. Autodesk Informed Design Help
  2. Get Started on Autodesk Learn
Release Notes with detailed description of all new functionality and bug fixes can be found on the Autodesk Help.
How quickly does it take a user to learn how to use Informed Design?
Any user can learn how to learn the functionality of Autodesk Informed Design quickly, but the following knowledge and skill levels are pre-requisites:
  • Intermediate Inventor usage (part modelling, creating assembly modelling, drawing creation)
  • Basic understanding of iLogic
  • Basic Revit usage
  • Understanding of Autodesk Docs / BIM 360 Docs
How does a user report a problem or bug?
Users can open a support ticket in the same way they do for any product via the Autodesk Account. To ask questions regarding workflow best practices or feature usage, all customers can post within Informed Design Community Forum to engage directly with the product team.
What is the plan/future (Roadmap) for Informed Design?
The public roadmap is available in the Informed Design Knowledge Center: 2024 & Beyond: Informed Design Roadmap
Will Informed Design be available or integrate with other Autodesk products?
At the date of release Autodesk Informed Design is only integrated with Autodesk Inventor and Autodesk Revit.
What are the current limitations for Informed Design?
  1. Informed Design is not compatible with Vault. See: Inventor Project Structure
  2. Informed Design is not compatible with Inventor FrameGenerator. Framing components created will not transfer.
  3. Informed Design is not compatible with nested Revit families.
  4. Informed Design is not compatible with certain Revit system families including:
    • Mechanical ducts
    • Plumbing pipes
    • Structural rebar
    • Curtain wall panels
Autodesk Informed Design for Inventor is an add-in for Inventor which gives a product engineer and/or designers the ability to share their design models with designers using Autodesk Revit.
What version of Inventor does Informed Design work with?
Informed Design for Inventor works with Autodesk Inventor 2024 and will be made available for upcoming releases.
Where do I download the Inventor add-in?
The Informed Design add-in for Inventor can be downloaded from the product page or directly from https://informeddesign.autodesk.com/ by clicking on the information icon.
What level of Inventor skills are required to use Informed Design?
When using Autodesk Informed Design for Autodesk Inventor it is important users have a proficient level of experience using Inventor (part modelling, creating assembly modelling, model states, drawing creation).
Does Informed Design require the Inventor user to know iLogic?
Yes, at least basic level of skills using iLogic.
Autodesk Informed Design Add-in for Autodesk Revit allows designers utilize product manufacturers products with the constraints defined by the manufactures in their design models.
What version of Revit does Informed Design work with?
Informed Design for Revit works with Autodesk Revit 2024 and will be made available for upcoming releases.
Where do I download the Revit add-in?
The Informed Design add-in for Revit can be downloaded from the product page or directly from https://informeddesign.autodesk.com/ by clicking on the information icon.
What level of Revit skills are required to use Informed Design?
When using Informed Design for Autodesk Revit, users should be experienced in manipulating views to efficiently navigate and analyze their design. This includes tasks such as adjusting the visibility of elements and managing view templates. Additionally, proficiency in loading, placing, and editing families is essential for accurately representing objects and components in the design. Knowing how to save and publish Revit models to Autodesk Docs is crucial for effective collaboration and documentation.
Does Informed Design work with Revit LT?
Autodesk Revit LT does not support the use of add-ins. A full version of Autodesk Revit is required to run Autodesk Informed Design.
The Autodesk Informed Design Web Application is a tool that facilitates the collaboration between product manufacturers and designers. Specifically, manufacturers using Autodesk Inventor can publish their product designs for Autodesk Revit designers to use during their design process. The Web Application also integrates with Autodesk Docs, enabling users to control permissions and generate output of all manufacturable product information directly from the designer's Revit model.
Who has access to the Informed Design web app?
The Informed Design Web App is typically used and managed by the product designer. This individual is responsible for publishing the product definition or generating outputs through the application.
What cloud security requirements does Informed Design follow?
Informed Design aligns with Autodesk Security framework which is designed around industry standards. Please refer to the Autodesk Trust Center is a customer facing website containing information about our security program, security advisories, third-party audit reports and certifications of our cloud products.
Informed Design and Autodesk Construction Cloud
Informed Design integrates with Autodesk Construction Cloud as app similar to our partners third-party applications connects.
Is it just ACC or does Informed Design work on BIM 360 as well?
Yes, Informed Design works across both Autodesk Construction Cloud and BIM 360.
Is Informed Design available to use on both the Americas and European servers? ie. EU, and/or US server.
Currently, Informed Design is only supported on Americas servers. Therefore, when working on projects using Informed Design, they must be created on an Americas Server and not on a European Server.
Who provides licenses to access the ACC project when working with Informed Design?
The licenses for accessing an ACC project when working with Informed Design are typically provided by the product manufacturer who is publishing to their own ACC project. These licenses are necessary for their team to access any information published to or saved within the project.
If users from outside the organization need to access the projects, they can use their own licenses under the "bring their own subscription" model. This model is applicable to Autodesk BIM Collaborate, Autodesk BIM Collaborate Pro, Autodesk Build, and Autodesk Takeoff.
Furthermore, project administrators have the capability to invite members to use a product on their project without requiring an account administrator to assign them a subscription.
Minimum Permissions Requirements
Informed Design utilizes Autodesk Docs and folder permissions to manage access when using Informed Design for Inventor and Revit.
Autodesk Docs Folder Permissions
 The folder permission levels are defined as follows:
Permission level Description Action
View View Only View files, add private mark-ups and create issues.
View View + Download View and download files, add private mark-ups and create issues.
Create View + Download + Publish Mark-Ups  View and download files, and create issues.
Create View + Download + Publish Mark-Ups + Upload View, download and upload files, and create issues.
Edit View + Download + Publish Mark-Ups + Upload + Edit Create folders, share your own files with members, view and edit any other files in that folder and publish mark-ups.
Manage Full administration controls Create folders, share files with members and view and edit any other files in that folder. With Manage permission, you can carry out the same folder tasks as a project administrator.
Note: This information has been taken from the Autodesk Docs folder permissions help here
Informed Design for Inventor Permissions
To publish product releases with the Informed Design Add-in for Inventor:
Autodesk Docs: Your permission level in the target folder must be Create – ‘View + Download + Publish Mark-ups + Upload’ or higher.
Informed Design for Revit Permissions
To insert and update product instances with the Informed Design Add-in for Revit:
Autodesk Docs: Your permission level in the product’s containing folder must be View – ‘View Only’ or higher.
To assign instances from a Revit model in the Informed Design Web Portal
Autodesk Docs: Your permission level in the Revit model’s containing folder must be Create – ‘View + Download + Publish Mark-ups’ or higher.
Note: Users with View – ‘View and Download’ permission level in the Revit model’s containing folder can open the model in the Informed Design Web Portal, but they cannot assign instances.
To configure and submit a request for outputs in the Informed Design Web Portal:
Autodesk Docs: Your permission level in the target folder specified as the upload location for result files must be Edit or Manage.
To access the Releases tab for product administration:
Autodesk Docs: You must be a Project Administrator in the project that is selected in the header navigation bar.
Note: Project Administrators have Manage permissions to all folders. Docs allows Project Members with Manage permissions at the folder level to carry out project administrator tasks within that folder, but this access level is insufficient for release management in Informed Design.
0 REPLIES 0
Sign-up for a Live Demo
