Impression (Read Only)
Autodesk Impression
11 REPLIES 11
Message 1 of 12
2652 Views, 11 Replies
Autodesk Impression
I'm trying to import and/or open a DWG file in Autodesk impression and this is the error message I am receiving.  I have gone through other tips and made a couple .dll to .bak files as suggested.  I have also back saved the DWG to 2007 just incase that was an issue and I still can't open the file.  Please help!
11 REPLIES 11
Message 2 of 12
pendean
Can yon open this DWG file in AutoCAD? The error message is telling you the DWG file is dead.
Message 3 of 12
in reply to: pendean
The file opens in AutoCAD and AutoCAD Civil 3D.
Message 4 of 12
I also just downloaded the Impression software so I don't know if there is other issues that I need to correct with it.
Message 5 of 12
pendean
Can you share the file with us here? We all have IMPRESSION, which by the way hasn't been updated for many years and may not actually work with C3D content if that's present in he file.
Message 6 of 12
Here is the drawing I'm trying to import.  Thank you for the help.
Message 7 of 12
pendean
Your file would not open unless I truly knocked it down to R2007 format with AECTOACAD command from inside AutoCAD first. It appears some content got lost.
There are better programs out there than Impression which was last touched by AutoCAD in the year 2009: some are free, most are not.
Message 8 of 12
Thank you so much for your time.  If you wouldn't mind could you suggest a more updated software.  Have a great day and thanks again!
Message 9 of 12
hi Conroy,
where did you download this software from? I have fully licensed AutoCAD software but cannot find this anywhere?! can you help at all please?
Message 10 of 12
Conroy where did you download Impression from please?
Message 11 of 12
pendean
Impression is a dead product from Autodesk from the year 2009: you can find it buried deep in your current Autodesk subscription "other software" link.
Message 12 of 12
pendean
We use Adobe Photoshop and Illustrator for the task or creating presentation quality graphics of DWG file content in our office: there are "free' alternates to those two that you can search for on the web.
