wonky coordinates
wonky coordinates
I really don't understand this but I've noticed that often when I drop something into a design and then move it, the component /looks/ like it's in the right place but then when I try to do something like align a plan to its surface, it's actually back where it randomly dropped in (read: very much not where I wanted it to be)
I'm not sure if that's a bug or a misfeature but it'd be nice to at least have the option to be able to start sketching in the plane defined by where the surface of a component appears to be in a design.
misplanes
Note that that blue construction plane (upper left) is actually on the surface of that mounting reference body (lower right).. or at least it should be and that's where I wanted it to go.
2 Comments
Ah - I finally found «ground» after which I get what seems like it should be the default behavior. I can almost imagine a scenario where the other way might be interesting or useful.. but the current approach is at least counterintuitive and feels like it would be something safe to bury / remove as the default behavior.
keqingsong
Status changed to: RUG-jp審査通過
