use dimension value from solid command also for sketch dimension
would be great to make the sketch distance use the thickness value for a thicken command.
5 Comments
HughesTooling
Can't you just enter d16 in the dimension or +(d16) like this, or am I missing something?
Mark
cekuhnen
Yep this works already - because D16  -3mm  I have to write d921= -(d16)  to turn -3 into +3 mm.
While this makes sense it would be nice to use -3 as well so a line can be left (negative y) or right (positive y)
that doesnt work.
So maybe this idea should be changed into how values are used.
HughesTooling
I see what you mean now, I suppose one option would be a function that would return an unsigned number, something like unsign(d16). Or just make dimensions ignore the sign but that would be a bit ambiguous.
Mark
Edit Just remembered there's a function already, you can enter abs(d16) and you will always have a positive number returned.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
