Hi Guys,
I could use some help with this - i am using a cnc gang lathe CMS GT27 with 8025 Fagor control
So i have been having this issue for a long time and have asked about it in the past and the response is it is in the post processor. I have tried to make changes and all looked ok for a little bit but when i started trying to cut a radius is where the issue happens the worst. so for the most part i have given up and i come to the realization that it is not the post processor and here is why
1) when setting up the lathe tool holder in edit tool i select Counter Clock Wise direction but the tool just flips over then i select the orientation to the way it is installed on the Lathe that would be from the X- to 0 not the normal X+ to 0 and then the path generation is unable to create a path. it gets path error and it trying to generate the tool path from the X+ to 0 direction
2) when i leave the tool oriented from the X+ to 0 but CCW selected, then it creates the code but it uses G03 and all positive X values.
3) i change the G03 to a G02 and also change the X values to be negative but the radius is still not correct.
So you might ask please upload a the drawing but that is not needed, just make a .5 cylinder 4" inch long and a .25 radius on the end and you will have the drawing also use any post processor that comes with fusion - i use Haas Lathe same issue
use any tool you want. but fusion 360 will not be able to produce the code to use the tool from the negative X direction. only works good as long as the tool is from the X positive direction.
It would be nice if the Fusion group would address this issue instead of claiming it is a post processor issue. It is not - it is related to a core limitation in the software it self !!!!!
Then you guys say -> fix this in the post processor.
So to fix this in the post processor is the wrong place and could also be dangerous. if you make the mods and get used to using it that way and then add a tool from the other direction and crash. (yes you should verify the tool path every time but if ignored could cause some issues.) so then have different post processors for each tool variation. pain in the ..
So the root of the issue is located in the Lathe Tool Edit page under the setup tab and it lets you select witch way the tool is pointing but if you select the lower arrow (X- ) it will still put the tool above the center line of the material. It should drop the tool below the center line to be correct and then generate the tool path in the Negative X. otherwise that selection in that menu is useless and should be removed. also to add a picture of a peace of material in the middle of the arrows for orientation would be good.
as far as The clockwise or counter clock wise checkbox, It should be changed to read tool facing upright or upside down - the spindle direction should be derived from the direction the tool is pointing at the material and if it is upright or upside down to do it correctly, and then place the tool in the drawing in the correct orientation.
i wish the fusion group would address the issue instead of passing it off as a post processor issue - it is a fusion issue and needs to be fixed, so far it looks like you know it but do not address or
maybe have never used it to machine anything and don't see the importance.. I guess if your market is just hobbyist then who cares whether it is correct or not but if you are trying to compete with real professional software then it should be fixed.
Its funny, i have seen a lot of the help vids put out by people from autodesk and showing how to use the software, how to use the CAM processor And it has been very helpful, But i don't think they have ever cut a single chip with the code it generates. it would be nice to see if the developers that made the Videos could Actuality use to make a part from the generated code.
So please fix the issue in Fusion, it is not in the post because that is not the correct way to fix a programming error.
Question:
I need a crow bar to pry with but i could use a screw driver to do it, Is that the right way ? No!
Please let me know if any other ideas to fix this issue
Thanks for any input
Mitch
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
