To Reduce file size of .f3d and .f3z
Hi
     In my design there are a lot of joint and it is quite large file with 125MB of .f3d file
     There should be an option for file size reducer.
     Due to joint and constrained my PC is not correctly working on this project.
    After giving a command One option of "Send Report" comes and whole fusion file close up
     can we solve this issue.
    I am still unable to solve this issue of File Size.
    I have already loose my some design  Data of Project which I have done within 5 Minutes or less. Due to 5 minutes file saving time
     automatically in Preferences of User Interface.
1 Comment
Fusion is not able to handle larger Project file.  There should be an option for File size reducer so that it can work properly.
It is due to Constrained joint.  If a constrained is provided between components then its file or constrained joint size should be lesser...
