Show only
Search instead for
We need to be able to build UCS relative to the screen view or other methods for 3+2 machining work....
I would like to be able to use my SpaceMouse to set up the tool access and the make the UCS so that i can select it under the tool orientation button within the CAM Module...
Currently i cannot do this but the select UCS option is available under the Tool Orientation window.... Weird .... Almost there !!
