To add a Split command in sculpting Environment body can splitted along a plane
7 Comments
In sculpting Environment a body should be splitted along a plane without loosing its T-Spline and should be maintained its geometry
cekuhnen
@Anonymous the result will 99% be bad geometry something T-Splines is not going to be happy about.
@cekuhnen
There should be an option of  Along Plane It should made a Projected T-Spline along a plane by provided a option.
Like in Model Environment It cuts a body  along a plane without disturbing geometry it is maintained. There is a pre built option in Model Environment otherwise it will also loose their geometry by Produced a Residual Stress of a body. But it does not looses.
We have to make an option which will constrained  a projected circle of Sphere along a plane. Now geometry will not loose their shape and remain constrained along this projected circle...
Can we make an option which is able to maintain T spline Rigid or Constrained at Projected area of a Plane
Build a New T Spline as constrained without loosing Shape of Geometry
@cekuhnen
After Splitting a Body with constrained T Spline in Fusion 360. It is a solution which we expect from Fusion 360 in T spline Environment.11.png22.png
cekuhnen
I am still skeptical of this. T splines is nothing else then under subD and this hate Boolean sin particularly when you want to later turn it into nurbs
Sent from my iPhone
cekuhnen
Sent from my iPhone
colin.smith
Status changed to: RUG-jp審査通過
We have had a similar request for trimming T-Splines with a curve or plane. This is a big project that we are unlikely to do.
