I would like to see a spiral option added to the Scallop strategy. I know that the initial though is, "Isn't that the same as Morphed Spiral?". To that, the answer is no. Morphed Spiral has the occasionally fatal flaw of not stepping over at a constant distance, or in other words, morphing. In some cases, that's great and it's the strategy to go with, but in others, it's less ideal than having a constant stepover distance such as that produced by Scallop.
If a spiral option were available in the Scallop toolpath strategy, the stepovers would remain constant as it does normally in Scallop, but with a spiral pattern to the toolpath, there are many applications where a continuous motion would produce a superior finish to the current model, which is to produce links between passes. Those links can in some cases be a visible line, like a witness line. If the pattern for Scallop were a continuous spiral, either conventional or climb milling in direction, these lines would not be produced and a higher quality finish would result.
