Right now Fusion doesn't have a quick way to sketch lead in chamfers. It would be great if the chamfer tool was a little more intuitive where you can select an angle and length then chose what face you want that chamfer to be on. This would help on round parts you would machine in the lathe.
Example would be a 15 degree angle and .200 long. This would be a lead in for a sleeve that needs to be press onto a shaft.
