SAE J1926 ports as an option for holes/threads
SAE J1926 O-Ring interfaces are the standard for the automotive aftermarket for most fluids and are used on everything from fuel injection to coolant hoses.
As far as I can tell there is no quick way to accurately create this feature in Fusion. Its not sufficient to add a chamfer to a counterbored hole as this standard actually has two chamfers. The first chamfer is 12 or 15 degrees which then leads into a 45 to allow space for the o-ring to seats.
4 Comments
josh.sapp1
They are used a lot for SCUBA equipment also. It would also be nice for Stub Acme to be a thread choice.
colin.smith
Status changed to: オートデスク今後検討
colin.smith
Status changed to: RUG-jp審査通過
jeff.castle
Is there a reason this got archived? Is there a resolution?
