Roughing strategies.
I'm missing roughing strategies more and more when im doing CAM work with fusion360. The ability to do deep slot plunge milling with a large insert tool that is not center cutting for example.
Would make it possible to remove a heap of material before going in and claening up with a more traditional tool path.
3 Comments
Missing roughing strategies?
From the description you are just missing one strategy, or are there more?
andreas
If you add it to the existing dialogs where you have a "roughing" option.(pocket, countour, slot even tracing would benefit from this)
You would get several strategies having a roughing option.
Atm the roughing options just make several passes until its close instead of really hogging out material and then swapping over to a interpolated path. And usually when cutting hard materials you would need to make it multiple depth ontop of that instead of using say 20% of the diameter of the tool from an edge inside or outside just plunging straight down.
I find it when i program that by hand its much faster than adaptive clearing for example. Leaves a really rough end result that can be easily cleaned up with a countouring or tracing operation from there.
andreas
And im gonna add i using these strategies cuz i run older used machinery and dont have access to new fancy 5 axis stuff. with 10k rpm on spindle. I have a 2k spindle max speed, running an old Siemens 810M GA3 controller with 1 block look ahead. 😃
