Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Ribbon from Inventor
Can you please give the option to have a UI more similar to that of Inventor? I found the tabbed ribbon to be a very usefull time saver. In Inventor, I start a sketch and it maxamizes the sketch tab to fill entire ribbon. That allows me to do in 1 click what takes 3 in fusion. The dropdown is a massive time-waster and I think it would be much more efficient to have the software use the tabbed ribbon that Inventor had.
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jpåÆ©ęŸ»é€šéŽ
