reword/reposition keyboard shortcut for "rotate around point"
Description of "hold shift + click then hold middle mouse button = rotate around point" is confusing.
Much better, and much less confusing (IMHO) is: "hold shift + click middle button = set orbit center"
After setting orbit center,  then use "hold shift + hold middle mouse button = rotate" as before - this is always true, regardless of whether center has been repositioned or not.
Thus normal action is to rotate, set center, and rotate again etc.
This change is to documentation only - this is how F360 already functions!
2 Comments
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
