I'm currently working on an assembly with several countersink screws. These screws are sadly not in the parts4cad library.
Now I can create my own screw as a Fusion design and use the "Insert into Current Design" function - but for every length and every diameter, I would have to create an own design.
It would be better to create a "design pattern" (e.g. the parametrized form of a countersink screw) and, when inserting them into your assembly, you simply choose your own length and diameter (or other parameters).
In this "master design" you could even create a database with possible combinations. For example, my countersink screw would have the following database:
Thread size (fixed) | Thread length (variable) | Head diameter (fixed) | Head heigth (fixed) | Hex key size (fixed) | Hex key depth (fixed) |
M3 | (variable) | 6 | 1.7 | 2 | 1.2 |
M4 | (variable) | 8 | 2.3 | 2.5 | 1.8 |
M5 | (variable) | 10 | 2.8 | 3 | 2.3 |
M6 | (variable) | 12 | 3.3 | 4 | 2.5 |
M8 | (variable) | 16 | 4.4 | 5 | 3.5 |
When you need a M3x23 screw now, you could very easily insert it - just select your thread size (M3) and type in 23mm under thread length.
