Point-to-Point move with one or more axis locked
This adds 3 checkboxes under the "point-to-point" as []X []y []z.  They're all selected by default (which is the familiar use), but you can deselect any so that when you click "OK" the deselected axis remains unchanged.
This would be especially powerful if additionally a button labeled "coordinate" would allow you to select a plane, or 2 orthogonal axes to redefine the coordinate system used when locking one or more of the axes.  Understandably that will probably require another feature request so I'll be happy if just the first paragraph above was implemented.
3 Comments
jlauer
I agree. I need to move my dispenser up a smidgen on Z, but don't want to lose the centering of the needle point. There does not seem to be a way to get the base of it level with the platform it sits on without me figuring out the offset (which is many decimals) and then entering a number move, which never gets me to a 0 accuracy. Number one frustration is not being able to do a point to point move on one axis. I mostly end up moving the whole component and then re-positioning through lots of gyrations.
keqingsong
Thank you for posting your idea! The idea is now 2 years old and does not have many votes, so we are going to archive it. If this is still important to you, please make a new post with the idea included. You can follow the idea submission guidelines here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
