Show only
Search instead for
Previously when I used to work with Pro-E I used to use X , Y coordinates . and define holes which was very convienient . Glad that you have brought this to concern. Have my kudo
Also it is time consuming for me to define each and every hole a reference edge. Rather than that I can start defining the X and Y coordinates from a reference point in a table .
THis is a just a suggestion for our side to bring this option.
@Aadithya01 other 2D programs I have use X and Y positioning as well one of them is a ADSK program, it's one of those hard ones, If we could just have it for points That would be very good points can be used with more than the hole tool, and would give what's needed for the hole tool, I vote for it I would like it for points.
A script probably could be done for points as well.
I only miss being able to slap points in where you wont them, being able to just diamention stuff in I find is just faster other than slapping lots of holes in.
@autocad It's still a very good idea if we only get the points that would cover both sinces you can pick points for the hole tool
