Parametric Engine is performing intolerably slow, affecting today's bottom line.
I am getting tons of error, restarted app, restarted CPU. Horrible terrible lag. Tons of meaningless errors, failures in holding constraints, constraint vectors not respected. Bad. Bad I tell you. Bad.
I will wrap up this task, however long it takes, bill my client extra for the extra time it took to do the task and hope there is an update coming soon to address these issues, otherwise, I am going to loose work and productivity.
Not Happy.
1 Comment
Same problems here. You could look into Inventor if you do serious work. The LT version is quite affordable. Downside is, you will need Windows.
