In cases where you may need to create a dimension to an area that is reduced by a cut (like the original diameter of a shaft prior to cutting gear teeth in it) you may need a dimension that you cannot identify on a drawing. In other CAD systems you can sketch a line or use a datum plane to dimension to.
