More organized file recovery dialog
The File Recovery system has made some dramatic improvements.  When I had to use it recently I thought, it would be nice if this data were a little more organized.
Maybe instead of a long string of data it could be separated into columns or cells.  Also, a thumbnail of the design would make it easier to recover if you crash with many files open at once.
I've had times where I click through all of the designs just to make sure they are still up to date, not being sure if I had saved them before the crash or not.  A quick glance at a preview image might tell me the same without a lengthy process of opening each file individually.  This would also help when there are multiple unsaved designs to sift through.
 Current File Recovery:
:File Recovery dialog actual.jpg
Proposed File Recovery:
