Mirror movements problems
When I try to move an element, which has a child (mirrored object) it makes some silly reactions (see video) I pull the object down, and it start to go up and down. I think is a constraint problem. I tried deleting the constraint "mirror" and than it works. Maybe can be improve this think without deleting the "mirror" constraint
3 Comments
TrippyLighting
I'd check out what the reason is for the yellow highlights of the icons in the timeline.
Chances are that those is the cause for the strange behavior.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
