while I love the simplicity and orderly approach of the UI having to switch constantly between patch and model space is often a nuisance when you have to work fast. specifically when you work in a process that combines both types of geometry.
In Onshape you have only one space and can switch between extrusion solid or surface which for there limited toolset is also fine.
In Fusions case I would love to be able while in model space be able to call the surface stitch command and apply that to the
selected surfaces to turn it into a solid.
But currently the toolbox filters appropriately also the possible tools for the current mode.
Maybe add the ability to do both!
