Lathe drilling and tapping
I would like to see Lathe drill/tap. I'm pretty sure it's not currently an option and the mill side doesn't work since there are no mill/lathe post processors. I really could use this option. Thanks
5 Comments
Drilling and tapping works in turning machines.
Maybe you are using a old post processor?
But drilling and tapping on the centerline should work fine with the lathe posts.
sin_arms
I've tried every post that comes with it. Simulation works great and when you go to output gcode you get a "failed to post process". I could be totally missing something but I don't believe I am.
Ok,
we would need a little more info to test your problem.
Maybe make a thread here so people can help you figure this out: http://forums.autodesk.com/t5/computer-aided-machining-cam/bd-p/2070
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
