interface and tools with expose
Couldnt Autodesk make a tool like expose on the MAC (I believe windows also has it ripp it) to show the tools you want?.
I know that if you press right mouse button the marking menu appears, but an expose system would be a lot easier.
We could select the tools we need /use the most and by pressing a hot key a window or several would appear in front of the screen, allowing us to quickly select the tool and get ride of the windows in a fast way.
Thanks.
3 Comments
daniel_lyall
press s then first letter of the command you wont
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
