Insert STEP (and others) inside Basefeature
please allow professional users to import and place CAD data like STEP etc inside a base feature via the insert menu
and not the dashboard.
We have now new design from file - great!
Being able to insert CAD data right into a Fusion design is still more than needed for a fluid and fast workflow
and not having to deal with upload and process time before a designer can continue.
Screen Shot 2016-08-06 at 5.57.50 PM.pngScreen Shot 2016-08-06 at 6.00.48 PM.png
4 Comments
HughesTooling
If you look in the scripts supplied with Fusion there's a script open from web.
If you look in the script's folder there's a html file, if you copy that file somewhere you can call from Chrome it gives you the option to open or insert files from your hard drive or direct from a web url without downloading first. I'd attach the html file but for some reason attachments are not allowed on the ideastation.
Here's a screengrab from chrome of the html page. I tested and you can insert into a base feature or just insert.
Mark
cekuhnen
@HughesTooling
Wow what a nice find! This works. So fact is with this HTML working there is no technical reason why this is not already build into Fusion!
Seriously Autodesk WTH here!?
HughesTooling
@cekuhnen don't know why this is not built in!!
Here's a link to a tips thread with a cutdown version in the second post.
https://forums.autodesk.com/t5/post-your-tips-and-tutorials/open-files-direct-from-the-web-or-hard-d...
Mark
keqingsong
Status changed to: RUG-jp審査通過
Thanks for this idea - love to see the level of engagement here. Since HughesTooling already have a script available, you can also now use the API to create your own custom palettes so that this is more integrated into the product.
