In CAM, select 'inverse edges' when selecting contours
I recently wanted to chamfer all edges of a part but leave just one edge unchamfered.
I couldn't find an easy way to do this other than selecting the whole contour, selecting the complete contour again so it turns red, clicking the U-shaped icon in the HUD, selecting all the edges I wanted chamfered leaving only a single edge unselected and then clicking the green 'plus' sign to add the selected edges to the contour.  Although this worked, it could be a long-winded effort, especially if there are many edges or small edges that are easily missed.
Would it be possible to have an extra option via the HUD where you could select the one (or more) edge you didn't want and then click a button to select the inverse of what you have highlighted?
3 Comments
HughesTooling
There is an option to select the start curve then the end curve then a curve on the path. It does mean 3 picks but can help. There's also an option to pick the start then shift click the end for open pockets.
Here's a screencast to show the 3 pick method.
Mark
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
