I feel like these would be some simple and straightforward enhancements to the inspection tool:
- If you measure a filet in a STEP file it doesn't give you the radius, only the line length. Not very helpful.
- Measuring between lines gives you the distance between the points you select, but that isn't necessarily the normal distance. Selecting two lines should give the normal distance between them (i.e. measuring thicknesses and lines are // but not directly in line vertically)
- XYZ differences would also be nice
The inspection tool is underrated but is used extensively in reverse engineering and quoting machining jobs
Thanks.
