I currently have a sketch where 3 projection points have failed, and I have no clue where they are located. There are probably 50 reference points in the sketch and having the error highlighted in yellow doesn't help. It seems that the points have either been obscured by other points, or they are missing altogether. Navigating to each potential location, and checking if the error is there, is a huge time consumer.
The error messages are of no help. For example - Where is "Project22"? Presently there is no way to even relate a specific name to a feature.
I suggest 1 of two alternatives.
1 - double click the failure in the warning dialog to effect a zoom into the offending location
or
2 - add errors as a visible object feature, and allow error visibility to be selected
It's clear that F360 has the information about the error location - it just doesn't presently make it available.
Regards
Peter
