Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Import command
Import command
Would it be possible that the IMPORT tab will be added so that i can import models and directly open in the model space
1 Comment
daniel_lyall
use New Design from file, or the insert menu, To get other file type you import them through the data panel
