Impliment constraints that prevent flipping
I've seen a couple requests for this, but always for specific cases. It seems like it's a more general problem.
Currently it seems to be impossible to tell the solver that a constraint should not flip the current orientation of lines. As it is, if I put equal dimension constraints on the placement of holes in a sketch, it's even odds that the solver will flip them completely outside when I resize anything.
Apparently the same thing happens with tangents. Same thing has happened with right angle constraints. It's insanely frustrating, and I've resorted to manually setting each dimensions a couple of times.
3 Comments
daniel_lyall
it is a bug or just no one know the best way to do it, drawing in a slot can do the samething when you change its demention, the fix for it was a to add another constrant. it could well be the same for other things
colin.smith
This item has been archived due to a lack of votes. If you feel this item is important feel free to create a new idea station item.
colin.smith
Status changed to: RUG-jp審査通過
