When you currently draw a horizontal or vertical line in sketch, if it happens to be coincident to another vertical or horizontal line, F360 will automatically insert a perpendicular constraint.
This makes sense if the existing line is not horizontal or vertical, but I think it's a big assumption that the vertical line I'm drawing should be perpendicular to the one that exists. I would think it should gain a horizontal/vertical constraint instead.
Horizontal and vertical lines should be treated as special when they are drawn.
I hope that makes sense - and feel free to offer a reason why the existing behavior is better - but I'm always deleting perpendicular constraints and replacing them.
J.
