Show only
Search instead for
What I have discovered is that using the training manual there has obviously been an update to the program without an update to the training manual. If you look at the training manual and the current onscreen menu they are different.
The left image is from the tutorial PDF the right image is from Fusion 360 on 2017-3-18.
There is not Convert to Centerline on the new menu (in Fusion 360 on 2017-3-18) and when you click centerline under guide type is flattens the center.
Any Expert help would be Great. I completely understand the need for updates and greatly appreciate them. I wish someone on the development crew would update this tutorial manual or at least add notations for supplement pages added to an appendix in the back.
