Function Dialog Box Defaulting
   I am finding the new "Move/Copy" command very tedious to use. It's OK if your only working with one object and manipulating it in
different ways, but if you are working with a lot of components and a lot of bodies, and doing primarily the same thing, it's tedious
and time consuming to have to set up the dialog box every time you use the function.Why not have all the dialog boxes for all the editing
functions default to the last user setting (even if you reboot the program). This way you can do batch editing, (such as moving a lot of
bodies or parts around) without having to set up the dialog box each time you use it, but still maintain the ability to do different edits
to one object.
