Feature Suggestion: Tool Library Error Should Highlight Incorrect Field
If the shoulder length is entered wrong, the OK button becomes disable but there is no indication what feild caused the OK to disapear.
Suggest you highlight the feild in error so it is obvious (see attached picture).
Also, no definition for "Overall Length" or indication for what this corresponds to.  If length of tool holder plus  tool, then calculate this using other parameters.
1 Comment
al.whatmough
Status changed to: オートデスク審査落選
