export STL relative to point P
I take fusion models and import them as STL files into my simulation (read: game) software.
The simplest way for me to animate them is when the part origin is on an axis of rotation.  Sometimes developers design parts where this is not the case.
I wish I could add a point at the correct location and say "now export the model with point P as the origin".  Just as good would be to move the origin itself without rebuilding everything.
Please and thank you!
3 Comments
TrippyLighting
You may want to check out Meshmixer. It reads .stl and you may be able to re-define the origin fo rthe .stl with that app.
keqingsong
Hey there! Thanks so much for submitting your idea. Unfortunately, this idea did not get a lot of votes from the community, and now is 2 years old. We're changing its status to archived. If you still feel strongly about this idea, you can resubmit it. Check out some idea submission best practices here: https://forums.autodesk.com/t5/community-faq/ideas/m-p/5384681#M44
keqingsong
Status changed to: RUG-jp審査通過
