engineering tool box for calculation and automatic part generations
Calculation and automatic part generation for standard parts like
a) Bearing load and life calculations linking for picking a suaitable bearing form library
b) Pulley calculations and pulley and belt generations
c) Spring calculations and spring generations
d) Key and spline calculations Key or spline shaft generation
e) Gear calculations Gear generation
f) Chain and sprocket calculations chain and sproket generation
g) Bolt calculations with torque and loads
h) Simple Shaft and beam sections generation of shafts
I) different brake and power requirements calculations.
i want these features to be added from an engineer's perspective
i look forward for fusion to be developing as an engineer's tool and every engineer would require these basic tools for deisgn
2 Comments
Beyondforce
charegb
