Edit dimension box show parameter value next to name
When typing in a parameter name in the edit dimension box I would like to see the value next to the name because sometimes my parameter names are simple like t1, t2, t3.
1 Comment
promm
Thank you for your idea, this is getting changed to future consideration.  With the amount of work the sketch team has in it's backlog, it will be a while before we can get to this.  When work is started the idea will be changed to accepted.
Mike Prom
