Request to improve or enhance drawing section views in Fusion 360:
1) Section line is associated to drawing view objects or features. E.g. a section line through a hole should update when the hole moves.
2) Improve inference projection when creating Aligned section views. E.g. sketching the section line at a non-orthogonal angle through a feature. A point can be acquired, but you cannot continue the inference angle lock.
3) Add support for section participation. The user should be able to select which components are sectioned.
Jerry
Fusion360_Section_Line_Enhance_Request_2015-11-10_A.zip
